Rear drum and rotor, wheel bearing are they same?
Hello
i can`t find any info about this..
are they same?
I did rear Drum to Rotor conversion on my 96 hatch.. and wheel bearings needs to be changed
i have wheel bearing in good condition from my drum brakes...
an i need to change wheel bearing on my rear rotor brakes...
can i use wheel bearing and assembly hub from my old drum brake?
Sorry again for my English....
are they same?
Re: Rear drum and rotor, wheel bearing are they same?
I will answer to my question :D
So today i was bored and went to my garage ...
compared rotor hub and drum hub and whoalaaa they are exactly same...
except drum hub did not have holes for rotor mounts/screws... but its fine works good without it ...
already installed it and works just fine ....
Seagull Management
The offset is different. The bearing for the rear drum either puts the face of the hub in or out a little further, I can't remember which way it went. But I do remember comparing them and they are different. It's also the reason guys used to use the scarebird conversion bracket to do rear disc swaps.
MarkCayabyab
10-07-2017 11:40 AM
PaChiLa Leader
02-18-2009 05:21 PM
