do you guys use lube on your o-rings (IACV,etc) such as DC-111 paste?
I'm getting new o-rings for my IACV, and I was wondering if most people run them dry or not? It seems a thin film of something would help keep them sealing well and nicely for a long time? But I don't know if it would really help at all.
This pdf from Dow Corning says the "Dow Corning 111" can be used for rubber o-rings where they meet metal. Also, the Honda Service bulletin 99-030 (Recommended Materials) mentions it for
However, since the shop manual doesn't say you have to use it, I suppose you don't. It is probably a better grease for moving parts.
Yes, I just decided I don't need it. I hope this rambling has not bored you as much as I bored myself.
High-viscosity lubricant for rubber-to-metal and
plastic-to-metal contact. Also used for suspension
bushings and brake system seals.
Re: do you guys use lube on your o-rings (IACV,etc) such as DC-111 paste?
Yes you should always lube orings. Nothing like tearing a new oring when you're putting something back together. Or finding you tore it after its back together and leaking.
I've always just used a little engine oil.
Note to self: don't read Honda-Tech at 1 AM and giggle like a sleep-deprived idiot at thread titles...even if I probably couldn't help it otherwise
On a serious note, I don't see a problem in lubing o-rings...cuz torn o-rings are...dammit, I can't type this with a straight face!
XD
XD
Originally Posted by angrysmileyface
I need to buy stock in whatever lube this guy uses on all his holes.
Posted from Honda-tech.com App for Android
