95 civic wiring and sensor issues
Ive got a 95 civic with a zc motor i put in it i need help determining which wire is to the fuel pump i believe the wire into the connector is loose which is causing the fuel pump to shut off and on while driving if i play with the connectors next to the battery it turns it on so i was wonder if i could bypass the connector and just solder the wires for the fuel pump together. If i do this i also need to know what color the wires are for it i cant seem to find it in my manual anywhere so if anyone has what color wire goes to what that would be much appreciated.
the other problem i have is my vehicle wont stay at idle i am going back and forth if its the TPS sensor or the IAC sensor when i unplug the IAC it goes from pulsating to a faster pulse but if i pull off the connector to the TPS it stays at idle does anyone know any more specifics to what the problem might be i would rather spend the 35 bucks to get the TPS instead of spend 155 bucks for the IAC
Re: 95 civic wiring and sensor issues
Post pictures of the connector and wires you are wiggling. I don't think there are any fuel pump wires on the shock tower.
You should start by cleaning the IACV and FITV.
99ssinoc
07-02-2007 05:44 AM
