93 CIVIC HATCH d16z6 problem
i recently changed the injectors and head gasket from my honda civic d16z6 vtec motor but it doesnt want to turn on it only cranks but dont start what can it be cuz the fuel pump is working i check the timing and it seen to be in order wat else can it be ..help plzzz
Re: 93 CIVIC HATCH d16z6 problem
firing order on spark plug wires^ then check for spark since you changed had gasket make sure your timing belt is dead on and not a tooth off, remove your spark plugs and see/smell to see if all cylinders are getting fuel (no gasoline on plug= injector not spraying - could be you installed a clogged or inop injector(verify by using a nerd light on the injector connector and crank, it should light when touched to one or the other terminals in the connector= if lights then its the injector thats not firing. hopefully you used oem headgasket and torqued according to helms.
glockoma818
05-01-2012 02:43 AM
hmtcrxsir
13
01-19-2008 06:06 PM
