Already Searched - brake line problem
I was bleeding my brake lines and was stupid enough to let the reservoir go dry and now that I've refilled it, the line wont purge (if thats the right terminology). What I mean is no brake fluid will flow to the rear brake lines, which are the only two I have attempted to drain. Fluid drained out fine at first, but the reservoir emptied, and since being refilled no matter what I do the lines will not flow. Anyone know what the problem could be?
Modified by OKSolSi at 5:09 AM 4/21/2004
Re: Already Searched - brake line problem (2lua)
Yeah guys I've tried it all.
I've pumped the pedal with the bleeder closed to build pressure, then opened the bleeder, and nothing flows.
I've opened the bleeder and pumped the pedal and nothing flows, the fluid in the reservoir stays at a constant level.
And yes, I have someone pumping the brakes while I watch the line.
WhiteOnRice
Suspension & Brakes
10
11-03-2012 03:45 AM
Team Bukkake Sucks!!!
11
12-13-2006 09:27 AM
