h-t i need ur help??
i just got a 1995 ex and we did not see the it had been crashed and had frame damage done but they pulled it out left it nice u cannot tell but when i took off bumper if wasnt to great ... well it started i was jacking up the car to replace the cv joint boot ... so the first time i jacked it up it was fine nothing wrong but second time around maybe hour later i notice as im jacking it up the support where the jack goes pushed up and heard some noise and i noticed my hood whouldnt close so i open it up and i see the radiator is way high then normal so im like wtf i noticed also the support where u put jack been pushed up....well later on we come to find out its been crashed and they put some non oem bumpers supports as in the pic below will have circled well comming to find out the dam car been crashed it has weld spots on the lower support one and it had been bent up cause i was jacking it up so im freakin pissed .... so me and my brother bent it back so now hood close good ... but still i cant jack up the freakin car the new bumper supports did not look like oem ones they looked cheap and weak ... so now im thinking of buying the oem supports bottom and top one i dunno wat u call the lower one but the pic below should help i know a shop that can do it anyone know if buying a new oem one will allow me to jack up the car with out the damm thing bending and how much do both of those supports cost .... im prolly not the first one this happpend to but plz help me =\
Re: h-t i need ur help?? (dcsports)
well from what your sayin is that your frame got pushed in
happeend to my buddy he got in an accident and they took it off and now he has no front frame and just the body kit on saving his motor lol
take it to a body shop
get them to look
go for free estimates
get them to look
Re: h-t i need ur help?? (labatia)
well i wanna get the price of both supports cause i aint using those we bent it bak to normal but if i try to jack it up same thing will happen
when you bought it did the guy tell u that i was in a crash before and that it was "ghetto" rigged back together? if not i'd be going back to that guy asking for some answers or some greenbacks back hope u didnt pay toooo much for it
Re: h-t i need ur help?? (Donkey85)
hell i got the car with 118k on it the guy before me had it with 116k he said he didnt know about the damage it had
I guess your talking about the supports. Got confused by the useless history of the car. Anyways go to a junkyard and pick those things up. All they are is supports, which you can rebolt the ones now and place the new ones with. If I understanding your post correctly, it should just be plug and play. Good luck.
Re: h-t i need ur help?? (iluvGiRls)
ya ima have to weld it cause the one it has it welded so do i have to weld this one i dont even think those supports it has is for this car cause the bottom support is welded
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsports »</TD></TR><TR><TD CLASS="quote">ya ima have to weld it cause the one it has it welded so do i have to weld this one i dont even think those supports it has is for this car cause the bottom support is welded</TD></TR></TABLE>
This is what I would do. Wait to jack up the car and go to a junkyard and get some supports off another Civic. After that go to a welding shop or muffler shop and ask them a nicely and mature way to weld them on for you. Just be nice about it and they might do it. My lil' .02!
Nope don't think there's anymore to tell you. Just post some information when you get everything fixed or you need anymore blah blah..
are you sure you jacked it up in the right place? I once jacked up my friends car in the wrong place and the radiator support bent upwards and the hood could not close. stupid of me, but i learned. sorry i couldn't help. good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsports »</TD></TR><TR><TD CLASS="quote">anyone know the price range for this job jus to have it welded on?</TD></TR></TABLE>
If no one answers your question. Get a phonebook and look up welding shops or muffler shops and call them about the welding job you want done. Should't take more than 5 mintues.
Re: (B16Drag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Drag »</TD></TR><TR><TD CLASS="quote">damn reading that post was harder than reading some of my books!</TD></TR></TABLE>
Yeah I must admit the first post had to be read twice by me.
there is a jacking point right behind your front tire on each side. if you stick your head under there you will see it. that is a much better place to jack than those 2 tabs on the front end. also i hope you are not jacking on the radiator support. also a new radiator support is about $70. idk if that is the price you were asking about. also if you do get a new radiator support you can drill out the current tack welds and put the new one on and hold it in place with the bolts for the bumper beam. then you can either go to a shop and have them tack it or rock it like that. idk if that is what you are talking about for sure but good luck and jack on the side points from now on
