need help on this one..car keep on dyin out
my car would start up for like 4 seconds when i spray in quick start and den it would die out but it would sound clean when it starts up just for the couple seconds ..and i thought it would be the fuel pump and i just changed it and it still consist with the same problem...neone might know what the problem is?? PLEASE help me.. I need the car up and runnin
Life sucks without my eg6
try a messing with teh injectors, the injector wiring, the main fuese relay on the fuse panel, and for teh fuel pump, u can know if its working or not fairly easy. Right when u turn the key to the ignition, if your quite enough your should be able to "hear" it turn on
Re: (Nerologic)
yeah i just changed the fuel pump and its not delieverin enough fuel for it to start..and i tried checkin for the codes and that didnt turn out so good and..it keep on repeatin itself..so im not sure..but i blieve it might be the map sensor
Re: (posterchild)
there is some kinda main relay thats under the dash next to the hood latch that goes out, but when it goes out, it will work randomly, but when that goes outit messes with the fuel pump, it wont let it start sometimes....so check that out
