how to fix timing problem?
Old 04-26-2004, 04:05 PM
Jaydeep's Avatar
Default how to fix timing problem?
I put the car in first and hit the gas and the car slugs. It feels bogged down till the rpms rise up then it takes off. Then when I shift to second it does the same thing. sluggish then back to normal. I think its timing problem.
Could you guys tell me how to fix timing problem. How do I adjust it.
Old 04-26-2004, 04:08 PM
WhiteEG6's Avatar
What is it thats out of timing? crank cams? You need to give a bit more detail to your problem before you can get a correct answer.
Old 04-26-2004, 05:30 PM
743power's Avatar
Default Re: how to fix timing problem? (Jaydeep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep &raquo;</TD></TR><TR><TD CLASS="quote">I put the car in first and hit the gas and the car slugs. It feels bogged down till the rpms rise up then it takes off. Then when I shift to second it does the same thing. sluggish then back to normal. I think its timing problem.
Could you guys tell me how to fix timing problem. How do I adjust it.</TD></TR></TABLE>
more details? new motor, rebuilt motor, swapped motor, new car? Sounds like retarded timing or lean A/F ratio. Either way, more details please. What car/motor?
Old 04-26-2004, 08:06 PM
94civicNewbie's Avatar
You IMed me earlier. Still trial user. No permission to IM back. Sorry. Anyway. What happened to me is I put the new distibutor on and the three holes for the screws, on the distributor not the head, were alligned wrong. The hoyes manual said to use a timing gun to check the timing and loosen the screws on the distributor and adjust it by turning it clockwise or couter-clockwise. I didnt have a t.gun at the time so I just looked a at the old distibutor and saw where the screws had been aligned, then matched the position on the new dist. It took care of the problem. Im getting a timing gun tomorrow so I can do it properly. I suggest you do the same to fix it right. If you check your timing and get it right and the problem still happens it might be a vacuum leak I was told. Hope it helped you.
Timing Gun = Friend
Old 04-26-2004, 08:15 PM
DAguyLS's Avatar
^^in your signature it says something about leaving ur license at home. Thats the gayest statement i've ever seen someone put in the signature. You can get pulled over without your license, they just run your name and you have 10 days to prove you are who you are.
are you a mommas boy or something.......(oh no!!!! I left my license at home!!! I better be REEEEL careful then, huh??)) &lt;&lt;LOL
Old 04-26-2004, 08:16 PM
SOHC_MShue's Avatar
Default Re: how to fix timing problem? (94civicNewbie)
If he had a vacuum leak then the idle would probably be all messed up.
DAguyLS's Avatar
sorry ahead of time for that post.......I need sleep
Old 04-26-2004, 08:43 PM
Default Re: (slamdcivic)
Im a newbie man. I expect to get flamed. No harm done. But just cause you dont like it, its gone. Easy fix.
doggworld1233
11-17-2005 06:29 PM
staticrex
07-14-2005 02:57 PM
Jaydeep
04-28-2004 07:15 PM
Quick Reply: how to fix timing problem?
