Has anyone bypassed/removed thier charcoal can?
1 Post
Hey guys, i've taken my battery, moved it to the rear, removed my pass seat, and made a plate for nos, ecu, ecu harness, and the fuse box from the engine comparntmeant, basicly just cleaning it out.. the charcoal box... wtf.. it does'nt make power.. why is it in my car !!!!...
can i remove this, any ecu problems, what the hell is it.. etc, and i'll add a picture, cuase we all knows the picture gets the reply
Re: (slowhatch4now)
Jeep Grand Cherokee's have that same stupid POS. It only traps the gasoline vapors when the car is sitting there turned off. On most Jeeps it's right where the drivers front tire flexes so many people rip theirs off four wheeling and other people remove them.
Most people didn't notice anything different.
EVERYONE who has had it removed passed emissions.
So I say if you are removing all that other crap why the hell not.
Re: (hadehatch)
Removing it hurts your gas mileage and increases your emissions output, but not the emissions they test at the smog station. If you like smog, go spend 12 hours in Tijuana. A bloody nose, black boogers, clogged sinuses, dizziness, and that god awful smell are enough to make me adamant about retaining the smog equipment on my car. I don't want my car to smell like a big lawnmower...
Re: Has anyone bypassed/removed thier charcoal can? (DewMota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota »</TD></TR><TR><TD CLASS="quote">the charcoal box... wtf.. it does'nt make power.. why is it in my car !!!!...
Nor does your windshield...take that bitch out, It'll save you some weight and eliminate the need for A/C
If I remember correctly oh OBDII version b (all 99-00 model) have sensor in their as well as in the gas tank. So if you don't have it the check light will go on and you will not pass smog.
This is required because when you fill your tank with cold fuel it will expand if the air temperature is warmer than the fuel in the ground. As the fuel expands it has to go somewhere and that tank is to take the overflow of fuel, or vapors.
One of the tubes leads up to the "purge cannister". This is the "vent to air" route when fuel vapor pressure is too high. The vapors are captured in the purge canister and then sucked into the engine for burning when driving.
So you sort of don't want to remove that "plastic box" - unless of course you like the smell of gas fumes.
By the way, a high concentration of gas fumes around your car is not recommended. A small spark in the wrong place and -- BOOM!
Re: (DewMota)
I used the EK can instead of trying to fit the integra one when I put the B18C1 in my 97 HX. Works fine, passed CT emissions last December.
Re: Has anyone bypassed/removed thier charcoal can? (FlatBrokeHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBrokeHatch »</TD></TR><TR><TD CLASS="quote">
Nor does your windshield...take that bitch out, It'll save you some weight and eliminate the need for A/C </TD></TR></TABLE>
LMAO!! hahaha!
LMAO!! hahaha!
1 Post
Re: (Greasemonkey)
i just want as stripped engine bay as i can. car is total stripped, with the new block and tranny, hood, doors, and lca's / trailing arms i should be in around 1900lbs
mind you this is a 1999 civic sedan auto, now a 5spd, with nothing in it.
yooo dawg da wheels an sturrin wheel dont make power neidaaa, maybe i should take my doors off too, (ps, not EVERYTHING is about power ) (PPS, i dont really talk like that)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota »</TD></TR><TR><TD CLASS="quote">wtf.. it does'nt make power.. why is it in my car !!!!...</TD></TR></TABLE>
Marvelous!
Let's see some pictures of your car.
Marvelous!
Re: (citrEK)
i also have no idea what u guys are talking about...anyone know the exact name for this? or have pics...or could say where its located exactly?
For you guys wondering what charcoal canister is...
Its number 11 in this pic.
What its for? Believe it or not gasoline gives off vapors that are harmful for the environment and the charcoal absorbs some of them.
Is it necessary? Nope it isn't. JDM eg6's didn't come with them. And the one I had when I was stationed in japan ran like a bat out of hell. But the canister has little to do with your engines performance.
