NX nitrous kit on a SOHC vtec
i work at a car dealership and we have to take off all the xtra stuff people put on there cars. i.e: alarms, nitrous kits, etc... well i got a 03 rsx (type s i believe didnt really pay much attention to it all) in with a 10lb. NX system et up for a 50hp shot. would this be applicable to my car with little/no modifications and just outta curiousity, anyone running a nitrous feed on ur SOHC vtec??? pros. and cons. of nitrous?? i dont know much about juice,. thanks in advance H-Techers. holla
Re: NX nitrous kit on a SOHC vtec (GreaseMNKY)
https://honda-tech.com/zerothread?id=830530
https://honda-tech.com/zerothread?id=831387
The SEARCH button is a God.
Hope it helps.
Hope it helps.
Re: NX nitrous kit on a SOHC vtec (94civicNewbie)
Hope it helps.[/QUOTE]
i know how to use search, im just lazy right now thanks
Re: NX nitrous kit on a SOHC vtec (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">I've run a 55, 65, 75, and 100 shot on my D16Y8. I think you'll love it.</TD></TR></TABLE>
This man knows his SOHC N20 stuff.
also, what is the diff. between wet and dry kits?? one is a direct injection through ur manifold correct??
Dry kit = a Single N20 fogger just spraying N20 thru your Intake tube
Wet Kit = a Fogger sytem using Both Fuel and N20 spraying together and premixing for combustion
Direct port = Putting Fogger into the Intake manifold Most comonly into the runners, Make sure you use the Y8 IM for high N20 doses Dude to the Larger DIameters of the Runners any more Q's? just ask!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreaseMNKY »</TD></TR><TR><TD CLASS="quote">ryancivic2000; u mind if i pm you to get more info.</TD></TR></TABLE>
Sure. Not a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicNewbie »</TD></TR><TR><TD CLASS="quote">I believe that a good thing dont you? </TD></TR></TABLE>
yes you are a good newb
Re: NX nitrous kit on a SOHC vtec (SOHC_MShue)
might look into upgrading your clutch if you plan on spraying a good amount. i had the nx wet kit that i was going to use on my d16. i upgraded my clutch in anticipation of spraying, but i sold the nitrous and never used it.
