Help with JDM sidemarker install SEARCHED
TO start this off i Already searched and came up with no useable infomation.
I am useing 96-00 ek sidemarkers ( They look alot better then 92-95's)
I need to know the following:
-Placement on a 92-95 civic
-whats tools to use to cut into the fender without destroying it.
i know what i am doing with the wiring i just need some help with the actual install of these.
ANY help would be much appreciated...Haters and Flamers will be IGNORED!
Re: Help with JDM sidemarker install SEARCHED (HybridHatchC1)
http://students.washington.edu...e.htm
here ya go, hopefuly before the flaming starts
mike
and let us know how you make out, i'll be doing mine this weekend
mike
I used a dremel tool w/metal cutting disks. As far as placement i just looked for a good spot the measured it to get it the same on the other side. To make a guide I used cardboard to cut a hole that would fit the side marker then taped it level on the fender.
go to radio shack and buy the sheet metal nibblers for like $5
drill the center hole for the marker and then use the nibblers to get a nice shape.
the nibblers are easier to use then a dremel and you will run a much smaller risk of killing the paint
(Ive used both tools)
When you have it done post some pictures becuase i have a set of ek sidemarkers and I want to see how it look on an eg.
Re: Help with JDM sidemarker install SEARCHED (l0utkastl)
ok guy's , i am going to install them this weekend then i will post up pics. the only reason i want to know what the best tools to use are is because my car is freshly painted. i mean i havent even driven it yet it so damn clean. i know i should of cut the fender before paint
Re: (H22boi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22boi »</TD></TR><TR><TD CLASS="quote">does anyone know the exact spec. for the 5th generation prelude</TD></TR></TABLE>
Probably better luck in the Prelude forum.
92BlueCivic
05-12-2006 07:14 AM
zerogravitycrx
03-28-2006 03:10 PM
