gsr brakes on ek
gsr brakes on ek
if i get the rotors and calipers for a gsr are there any other parts i need for the brake swap? im only interested in the front swap for now. because the lug patern for the ek and dc are both 4-100. the bracket that the calipers mount to..... will i need gsr bracktets or will the ek ones fit the gsr's? anything else come to mind when i do the swap? let me know.
are u planning on putting these on a cx? is so im pretty sure ur gonna need the entire front knuckle assemble.
check import auto salvage for some good prices on brake swaps.
Change the entire front hub assembly in order to use the GSR front brakes.
Also, add the GSR lower control arms and
Front sway bar while your at it!
Feels tight on a CX trust me.
I did it!
Oh and get the rear trailing arm assembly with rear discs while you're at it.
Use the GSR/LS/RS master cylinder if you want mad tight braking yo!
I did it!
lowgman
01-16-2005 07:19 PM
