99-00 Si Lip on an EX.
Well I finally got a lip for my 00 ex and do I need to get anything where the clips will bolt up to the bumper? There is nothing that the bolts screw into on my bumper.
Thanks in advance.
Thanks in advance.
Re: 99-00 Si Lip on an EX. (CoxhEd)
if its the OEM Si lip then you will have 2 screws on each end of the lip that screw onto the side of the bumper. you will see small indentations on where to screw. and there will also be about 8 or 9 clips on that lip that will bolt onto the bumper
Re: 99-00 Si Lip on an EX. (slowEKsedan)
I know but when I put the bolts through the clips and into the bumper and it doesn't have anything to screw into...
if its a stock honda bumper it suppose to have 2 holes on the both side of the bumper and holes in the bottom unless you got the after market bumper
Re: (bigBOI_palooza)
the bumper has 9 spaces for clips. the oem lip should have those too. you need air clips, something something. can be found in hardware stores i believe. or spend 50 bucks at honda
