Bad 1st gear or clutch??
Ok here is the problem, I revved my car up to 4-5 rpm and it won't do a burnout in first gear. It jus laggs for about 1-2 secs. then it starts going WTF?? Do you guys think its my gears or my clutch? I can smell a burning smell is it the clutch burning? because i know its not my tires (obviously). So do I have to replace the clutch? or first gear? and how much will it run me?
Re: Bad 1st gear or clutch?? (HS2G)
100% clutch. when replacing clutch replace throwout bearing pressure plate and clutch disc these are what have to be replaced and flywheel if damaged.
Re: Bad 1st gear or clutch?? (cherryburglar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherryburglar »</TD></TR><TR><TD CLASS="quote">100% clutch. when replacing clutch replace throwout bearing pressure plate and clutch disc these are what have to be replaced and flywheel if damaged.</TD></TR></TABLE>
But resurface flywheel and replace only if necessary or upgrading
Re: Bad 1st gear or clutch?? (murtnabila)
would you know how much it would cost? sry for the noob questions I am a newb and this is my first car. Just trying to learn from my mistakes. What clutch would be reccommended and flywheel? Clutchmaster, act? I heard those are good quality. My budget is $800.
with 800 bucks you can get an act setup with flywheel from on of the sponsors in the sponsors market section of the site.
or you could get a dual friction center force and flywheel from summit sport compact for about 700 bucks.
Where are you located...I got a custom setup from ACCESS MOTORS for half the price of the ACT setup. I had ACT and I like this one better.
kd97accord
11-29-2010 09:25 AM
DRKSol
03-29-2005 08:31 AM
