code 14: iacv
code 14: iacv
i got a 96 civic dx automatic. things that i have done was a 5speed swap,y8 manifold,and a 96-98 manuel wiring harness. after i got the y8 manifold on there and got everything hooked up i got a code 14 and 65. the code 14 i can't figure out. i have checked to see if it is clean and everything. i was wondering if i have it contected to the right plug.
the guy i bought it from said he was running it obd-1. but i changed back the iat,altenator,and cleaned up some bad soldering jobs. the wires that i think go to the iacv where cut. i put them back together the way he had them. so that could be it. but i don't know?
as far as the code 65 goes the secondary o2 sensor plug i can not find it any where. i think it may have been cut off? where on the harness should it be and i will go from there. i may have to wire it straight to the ecu.
Re: code 14: iacv (SprayinCX)
blk/blu and grn or maybe grn/wht
there is an orange one, but you should not be using that. Also, you need to look at the "A" plug on your ecu, and check to see if the blu/blk wire is in a12 or a14.
dingusjt
11-07-2003 07:45 AM
