mid shifted and over reved
didnt see where i over reved too, heard clickiing noises after stopping, and the bolts on my cam gears were lose, 2 were missing, need help please
* B A N N E D *
1 Post
Re: mid shifted and over reved (jianwa)
****, coulda bent a valve or two. Gonna have to replace those missing bolts. Check your cam, may have to replace that too. Check its runouts and replace all the bolts on your valvetrain to be safe. I'd check all the binders for the cam. Check the valves too.
Re: mid shifted and over reved (Redline96LX)
damn low on cash, dont think i can replace my cams right about now, is there any other issues i should be lookin at and how much would all of this be, fixing it myself is out of the question, rough idle, kinda hard start,
who knows....if the cam gear bolts came off, the gears could of slipped.....could of jumped a tooth. But since it has a rought idle and it's hard to start.....I'm pretty sure it's a timing issue.....hopefully you didn't bend any vavles in the process. Anyways, probably won't be cheap to fix.....good luck
at the jetties fishin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jianwa »</TD></TR><TR><TD CLASS="quote">didnt see where i over reved too, heard clickiing noises after stopping, and the bolts on my cam gears were lose, 2 were missing, need help please</TD></TR></TABLE>
my advice, don't race a bruised engine when you have no money....because that's when you WILL break something.
case in point = you
case in point = you
JDM_EK4_Coupe
04-30-2007 12:19 PM
