throwing code, please help!
Old Aug 22, 2004 | 02:07 AM
integracivic94's Avatar
Default throwing code, please help!
cel light came on and its throwing code 22! vtec oil pressure switch! i've tried changeing it and its still throwing a code, just trying to reset the ecu if that doesn't work any ides what else it could be?
Old Aug 22, 2004 | 08:16 AM
Slow98sedan's Avatar
Default Re: throwing code, please help! (integracivic94)
Try and clear the code man. If everything went well,then once you pull the fuse to clear the code,when you hook everything back up and start the car the light should go out. If not either try clearing it again or check the problem again,make sure everything is hooked up. Also,check the code again. I had a problem,cleared one code and threw another right away. Good luck man.
..adam..
Old Aug 22, 2004 | 08:42 AM
spyderracing's Avatar
Default Re: throwing code, please help! (Slow98sedan)
Check your vtec solenoid?
May have debris in the screen. Check it and clean it then try.
asocallocal
Jun 6, 2010 11:30 AM
ek98
Dec 24, 2007 08:21 PM
civic-4-ges
Jan 24, 2004 08:28 AM
S2KILLA
Sep 17, 2003 05:56 PM
