b18b w/zex times.
b18b w/zex times.
i may pick up a zex kit for like 2 bills. I was wondering like what fuel system and what ignition upgrades i should do before putting it in my car. Also about what would i run w/like a 65 shot. My previous time was a 15.02 with a bad clutch. i got a new clutch so i know i am under a 15 sec 1/4 mile now. whatcha guys think?
Re: b18b w/zex times. (CivicHatchback14)
if ur a good driver, u better be able to hit 13's.. i was pulling 15.2 with my z6 and with nitrous and street tires i was hitting 13.8.. and especially with the b16 tranny you'll be flying...
All Motor Mentor
1 Post
I'm assuming that your Zex system is a dry kit and not their wet system? If it's the dry kit you don't need to worry about your fuel system, the stock fuel pump can easily handle a 65hp shot. As far as timing goes use a timing gun and just retard the timing a max of 2 degrees (move the distributor towards the front of the car). Don't worry about your spark plugs either for that power level, just make sure you're not running platinum! anything else is fine. Make sure you run premium fuel as well.
wish my car was that light. 2080....
my car weighs around 2400-2480 depending what a I have in it.
could you imagine I be in the 13's
bw54867
09-29-2002 03:33 AM
