Which throttle cable???
New User
I have a 94 civic ex that used to be an auto and was converted to manual with a GSR motor.
I have now swapped my own B18C1 into the car and can't figure out how to mount the throttle cable to the pedal? I am using an ITR throttle cable, and it seems that there is a bracket missing. although it does pull at the throttle and open the TB about 2/3 of the way. I need to tighten it to get it to pull all the way. Otherwise how do i connect the throttle cable to the pedal?
also while i am at it. what is the size used for the heater hoses? 5/8 s? also what piece do those of you using a map sensor use to plug off the TB opening?
Re: Which throttle cable??? (Trak_Day)
ok I've seen this before. SOme times u get a cable that doesn't have the plastic spacer that goes the the pedle to hold it in. If you can find a 94 and up ls cable thats what I used on my friends car and it worked just right
Re: Which throttle cable??? (EK9Greg)
the cable wont stay connected to the pedal? of there is no way to connect it at all?
as for ur other questions it should have the size of the hose on the hose itself (if u have the hose).
and the map sensor im not sure exactly what ur asking here.
