...why does my drivers side front wheel feel like its a square?
ok, maybe im exaggerating a bit...it feels like im hitting a bump every half second but the passenger side feels fine.
Re: ...why does my drivers side front wheel feel like its a square? (makingplans)
you should check your front end out...ball joints, tie rods, axles, etc.
All Motor Mentor
1 Post
what kind of wheels are you running? Do they require hub centering rings? Do the tires have a broken belt or anything?
Re: ...why does my drivers side front wheel feel like its a square? (civicboisi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi »</TD></TR><TR><TD CLASS="quote">you should check your front end out...ball joints, tie rods, axles, etc.</TD></TR></TABLE>
sounds good to me
sounds good to me
Re: ...why does my drivers side front wheel feel like its a square? (99hatch)
also when was the last time you rotated tires? Tire pressure? Run ur hand long the threads and feel the tire...any bumps or lumps on it?
got tires rotated last year...i'll be doing that on tuesday or wednesday...and i guess i'll check what you guys are suggesting...thanks guys...quick reply ...oh yeah...stock civic ex rims on my ex.
Have you had to slam on the brakes recently? I did that one time and it caused a flat spot in one area on two tires. Good Luck
Re: ...why does my drivers side front wheel feel like its a square? (acuracrombie82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracrombie82 »</TD></TR><TR><TD CLASS="quote">Have you had to slam on the brakes recently? I did that one time and it caused a flat spot in one area on two tires. Good Luck</TD></TR></TABLE>
wow...that's some impressive stoping power to cause flat spots on two tires...usually tires get flat spots from sitting too long...never heard of the braking too hard one though...although i guess it could happen...
lock the wheels long enough you will flat spot the tires. my friend did it doing burn outs dragging the *** around both tires got flat spots on them
Re: ...why does my drivers side front wheel feel like its a square? (hayabusa160)
ya make sure you dont have any broken belts in the tire aka lumps and bulges
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">lock the wheels long enough you will flat spot the tires. my friend did it doing burn outs dragging the *** around both tires got flat spots on them</TD></TR></TABLE>
i dont beat on my car like that guys...hehe...
