CEL came on and now i checked it but still have a question?
So the other day I installed some ITR cams and after let the car run for like 10mins the CEL came on
So i shut the car down to check the code and put it in acc and the code went away
So finally I tried to check it as soon as it poped up with the car running
It flashed one time really quickly, then paused for about 2 seconds than flashed 9 time really quick
Is that 2 codes
1, and 9?
And if so why do they only come up after the cars been driven normally for like 20 miles, and sometimes doesnt even go one???
IT a chipped p28 BTW with a gsr motor
thanks in advance
Is that 2 codes
1, and 9?
thanks in advance
Re: CEL came on and now i checked it but still have a question? (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 »</TD></TR><TR><TD CLASS="quote">
Is that 2 codes
1, and 9
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle; from ECU thread »</TD></TR><TR><TD CLASS="quote">Watch your check engine light on your cluster. it will flash.. 1 long flash is 10. the quick flashes are one. so if ur CEL goes !.....!!! that is a code 13. !....!....!!!!! code 25. then take the code #'s and hop on this thread and see what it is. i hope i could help you all.
1 O2A - Oxygen sensor #1
9 CYP - cylinder sensor
19 Automatic transmission lockup control valve
Unless you've got an auto...
Is that 2 codes
1, and 9
yeah so its defenitly 9 but is that cause of the install or is it something that just happened?
crazyguy
08-21-2007 10:01 AM
