Clutch problems.....Not grabbing? Worn out? Please help.....
I am having a problem with my 92 Civic CX Hatchback. When i rev it up a bit and let off the clutch i can be completely off the clutch with the pedal to the floor and it wont go anywhere, the car stays in one position and slowly starts to move foward and then the clutch will grab and kinda do a chirp and start moving.....
But why is this? I cant chirp second at all, even get a decent pull on second, the car like hops because of the slow clutch grabbing? could that be it?
Anyone know anything ir have this problem before?
Thanks for the help in advance
Electrician
How many miles do you have on your clutch? Is it an OEM clutch?
Have you spotted any leaks of the Clutch Slave Cylinder or Clutch Master Cylinder? I had a leak on my Clutch Master Cylinder once and had no pedal pressure. So, when I revved it a bit and took off hard, the clutch would just slip like crazy and I didn't go anywhere.
gsr camel
09-13-2001 12:05 PM
