5 lug into ek axle question
i'm doing 5-lug suspension from an ITR into my ek hatch...everything is there including the e-brake cables to everything...my problem is, i've been told there's a problem w/ the axles...i still have my dx motor, so i can't just use ITR axles...is there anyway i can modify the axles on my dx to fit the 5 lug hub?...maybe change the end joints to itr?...i've already searched the forums and found threads on the conversion, but nothing about axle problems...any help would be greatly appreciated...thanks
Location: just when you thought you were different, WA, NWforLIFE
Re: 5 lug into ek axle question (orientalgunz_00)
if its a 32mm axle you should be able to use the same axles..if its a jdm itr 5lug which runs 36mm axles..you my friend must wait untill you gotta swap to use it..lol
Re: 5 lug into ek axle question (Leb_CRX)
usdm itr and ctr run 32mm axles...jdm itr uses 36mm...
only reason i wouldnt want to run the jdm itr 36mm is that if you **** one up...youre done...itll be somewhat difficult to get a pair...32mm on the other hand are readily available for our abuse
drdanny18
10-24-2007 03:31 PM
tr0n9h
12-10-2006 09:36 AM
