Tenzo R Version 5 Steering Wheel cruise control?
Ok I dont know if anyone has ever swapped a steering wheel on a civic with cruise control, but what did you do with the cruise control buttons? I would like to keep them. Any suggestions. The cruise control buttons are a ribbon and not just wires or I would put them on my dash with different buttons. Also how the hell do you hook up a horn on a aftermarket steering wheel. I need a power I already got a ground. How do I run the power through the steering wheel without it wrapping around. By the way I have a Tenzo R Version 5 Steering Wheel on a MOMO Hub. Thanks alot
Re: Tenzo R Version 5 Steering Wheel cruise control? (H22siCivic)
For the horn button there has been many write ups on it. Find the plug you disconnected for the horn and run a wire from it and you need to get a "shoehorn" that was used in the CRX I believe(correct me if i'm wrong) or if you're impatient just use a paperclip like I did. You will see a spot for a screw when you remove the hub, run the wire there as well as the screw and the shoehorn/paperclip and make sure it rests against the hub and viola, you have a horn. It sounds a lot more confusing than it is and if you managed to take off the wheel and put the new one on you could easily figure it out.
As for the cruise control......are u serious? Why do you need it anyway?
1 Post
Re: Tenzo R Version 5 Steering Wheel cruise control? (S(J)O(D)L(M))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S(J)O(D)L(M) »</TD></TR><TR><TD CLASS="quote">
As for the cruise control......are u serious? Why do you need it anyway?</TD></TR></TABLE>
cruise control is the best luxury item ever, i would go crazy without it...but i do drive alot of highway miles
I had another honda and I did the horn swap but this one is f-in weird. The horn's power was in the other steering wheel that hooked to the cruise control. the Cruise control and the horn ran off the same power which was a ribbon, not a wire. I have the ribbon hidden right now but I can't figure out how to run my cruise control because it is a ribbon and how to hook my horn up because it is powered with the cruise control. I have a 92 civic hb si.
It had to clip in somewhere right, not too familiar with the 92's but I would imagine a plug of somesort being there.
Coked GSR
11-25-2006 03:21 PM
turdb0
10
11-16-2006 11:40 AM
beeboyee
04-30-2002 11:53 PM
Wallace996
04-12-2002 08:43 PM
