ball joint/control arm install help
New User
i had to get a new wheel bearing pressed in, so i had to take my entire front right suspension on. Now im putting everything back on, and i cant get the two ball joints that u have to put a nut on to stop spinning while im trying to ratchet. I dont have access to air tools right now, so are there any other methods to tightening the nuts on the ball joints
Re: ball joint/control arm install help (CuttingEdge SI)
for the lower ball joint, use a jack and jack up the LCA to put pressure on it. try tightening it and if it keeps spinning, jack it more till you can tighten it to where you want it.
where did you get it pressed in at? cause pepboys is charging me $93 if i bring my car up there to press out the old lower ball joint and press in a new one
#1 Super Guy
Re: ball joint/control arm install help (hatchi)
With the car on jackstands, place your jack under the LCA.
Jack up the LCA until the car barely starts to lift.
Have sombody press down with all their weight on the rotor while you torque the nut down.
If you can't even get the nut bottom out BEFORE the balljoint starts spinning, you probably have a damaged balljoint stud, or castle nut (threads are jacked up).
Re: ball joint/control arm install help (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">With the car on jackstands, place your jack under the LCA.
If you can't even get the nut bottom out BEFORE the balljoint starts spinning, you probably have a damaged balljoint stud, or castle nut (threads are jacked up).</TD></TR></TABLE>
Location: South LA...107th and fig to be exact...for the foo
Re: ball joint/control arm install help (civicboisi)
i might just check the thread on the ball joint first or the nut...they seem to **** up real easy
