what would you recomend for a stripped head bolt?
Old 01-22-2005, 07:11 PM
Btothe3rdDegree's Avatar
Default what would you recomend for a stripped head bolt?
we are trying to get the head off a h23 and two of the bolts are starting to strip, what should i do? i cant use a stripped bolt remover because it wont fit
Old 01-22-2005, 07:15 PM
Unceasing Measure
Archidictus's Avatar
Default Re: what would you recomend for a stripped head bolt? (Btothe3rdDegree)
Lefty loosey, right tighty.
I kid, I kid. If you can't get bolt removers in there, you're probably going to end up hauling that piece of **** to a machine shop . You could always slot it with a dremel and try a screwdriver and vice grips, but headbolts aren't easy to move around, so I dunno.
Good luck.
Old 01-22-2005, 07:21 PM
zulued's Avatar
Default Re: what would you recomend for a stripped head bolt? (Archidictus)
how can u strip the head of a bolt....
use the right socket. a 12pt socket is ment for a 12pt bolt im guessing your using a 12pt on a 6 point bolt.
snap-ons motto is use the right tool the first time.
scarponze
Old 01-22-2005, 07:25 PM
Default Re: what would you recomend for a stripped head bolt? (zulued)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zulued &raquo;</TD></TR><TR><TD CLASS="quote">how can u strip the head of a bolt....
scarponze</TD></TR></TABLE>
no i am pretty sure that i am using a 6 pt, but thanks for the suggestion\
anyone else?
Old 01-22-2005, 07:28 PM
hatchedzex's Avatar
pretty sure?? lol count it.. i dint know you could strip a bolt with that high grade
Old 01-22-2005, 07:30 PM
I am a (Trial User) Army
litterbox's Avatar
Archidictus has the best idea. Dremel a slot into the bolt's head and use a flathead to get it out. Then get new bolts.
Old 01-22-2005, 07:37 PM
Default Re: what would you recomend for a stripped head bolt? (litterbox)
ok it sounds like a good idea but a 8 ft breaker bar cant get it off, a screw driver is supposed to?
Old 01-22-2005, 10:47 PM
mtetro99's Avatar
same thing happend to me awhile back, I had to used my dremel and cut the top of the heads off the bolt. they have alot of pressure so becareful. ohh, and if you do it this way plug everything you can, metal shavings are really bad for your engine.
Old 01-23-2005, 05:31 AM
Default Re: what would you recomend for a stripped head bolt? (mtetro99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtetro99 &raquo;</TD></TR><TR><TD CLASS="quote">same thing happend to me awhile back, I had to used my dremel and cut the top of the heads off the bolt. they have alot of pressure so becareful. ohh, and if you do it this way plug everything you can, metal shavings are really bad for your engine.</TD></TR></TABLE>
how did you get the studs off after that?
Old 01-23-2005, 07:55 AM
menkio's Avatar
you can get a flathead bit for a rachet/breaker bar
Old 01-23-2005, 08:10 AM
chris_c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree &raquo;</TD></TR><TR><TD CLASS="quote">
how did you get the studs off after that?</TD></TR></TABLE>
once you cut the head off the tension is released on the bolt [well the the threaded portion that is remaining]. it will spin right out at that point with minimal effort.
can't get in there with a socket of this type?
sears bolt out sets...
all else fails, you can weld a good nut onto the stripped head of the bolt...
Old 01-23-2005, 08:46 AM
RedlinedVTEC's Avatar
Default Re: what would you recomend for a stripped head bolt? (chris c)
I'm going to go out on a limb here and guess some of you posting have never taken a head off. The bolts are reccessed which makes his options limited to what he can do. IMO the dereml slotting idea is worthless. One I don't see how he could get a dremel in there to slot the head and two he'll still have a hell of a time getting them loose. I say just drill the heads off the bolts. Or take it to a machine shop and they'll do the same for you.
Old 01-23-2005, 08:51 AM
CivicSIR95's Avatar
Use a bolt remover! It should be able to get it out without it getting more striped.
Old 01-23-2005, 08:54 AM
Paprika's Avatar
Default Re: what would you recomend for a stripped head bolt? (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to go out on a limb here and guess some of you posting have never taken a head off. The bolts are reccessed which makes his options limited to what he can do. IMO the dereml slotting idea is worthless. One I don't see how he could get a dremel in there to slot the head and two he'll still have a hell of a time getting them loose. I say just drill the heads off the bolts. Or take it to a machine shop and they'll do the same for you.</TD></TR></TABLE>
When the dremel idea came up I was like WTF.
Old 01-23-2005, 08:55 AM
khmboostedeh2's Avatar
Default Re: what would you recomend for a stripped head bolt? (CivicSIR95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSIR95 &raquo;</TD></TR><TR><TD CLASS="quote">Use a bolt remover! It should be able to get it out without it getting more striped. </TD></TR></TABLE>
did u even read the thread?
if all else fails ...maybe try hammering a slightly smaller socket onto the bolt?
Old 01-23-2005, 09:13 AM
mrbsponge's Avatar
i used a bolt extracter like the one above, they have one for the 14mm size and it can be re used on other bolts, not justa one time deal, and it worked perfectly, i even used it on my air impact wrench before to help get head bolts out, give it a try they are like 20 bux at autozone for a set of them
Old 01-23-2005, 09:25 AM
Mr. Badwrench
boostedcivicsir's Avatar
on a few isuzu's i have had had stripped head bolts, they use 10mm hex's. drill the head off, and lift the head off like the block is studded. then take the part thats left out with a pair of vice grips.
Old 01-23-2005, 09:27 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Lefty loosey, right tighty.
Good luck.</TD></TR></TABLE>
MAYBE with a large bit and impact driver that might work, but a screwdriver wont loosen a headbolt..
Old 01-23-2005, 09:32 AM
quik1's Avatar
Default Re: (mrbsponge)
I've had this problem too, your going to have to drill the head of the bolt off as others have said. Don't worry about the stud it will come right out. You can try drilling a smaller hole and using a bolt extractor but you'll probabally just twist it. You will be able to clean all the metal shaving with out any problem, just cover the oil return galleries. Good luck.
Old 01-23-2005, 10:28 AM
Default Re: (quik1)
yeah i have done this before on my d16 (well three times now)
i cant use those sockets in the picture because the two bolts that are stuck are against the wall of the head and it wont fit, what do you guys recomend to get the heads off? just drill down the center of the bolt? can i even do that?
Old 01-23-2005, 01:36 PM
Default Re: (Btothe3rdDegree)
Well if you'd read through the replies it's pretty obvious what you need to do... drill/grind the heads off then when you remove the head the left over stud can be removed with little trouble by hand.
r90crxhf
08-19-2011 04:24 PM
EFstyle
23
01-27-2007 10:49 PM
spidermancivic
10-03-2006 09:41 PM
redm3turbo
10
07-20-2006 01:36 PM
The Destroyer
02-19-2005 01:47 PM
Quick Reply: what would you recomend for a stripped head bolt?
