hi... my car died
hi... my car died
i have a 92 cx with a b16a. today while at a stop light my car just died and will not restart. fuel pump does make noise so i think it works. no spark comin from out of the plug i pulled. when i turn the key to the second position i do here a relay click so i dont think its the traditional honda main relay problem. car turns over at normal speed so i dont think it is the timing belt either. i think its the coil or iginitor. any other ideas would help me on my quest so if you have any pls let me know.. thanks
Re: hi... my car died (cockrumracing)
yes the igniter and coil can fail while the car is running. it happened to the guy that owned my car. Easy, but costly fix. I bought a brand new dizzy from distributorking.com and it started right up. but if you are getting no spark but power to the dizzy then that is your problem. The dealer says that happens in the 92-95 year hondas often.
Re: (doug piston)
Yeah my ICM went out one day while i was just crusing to work on the highway at 70. new ICM costs at least 150 dollars... if thats the problem i would look into a used one on here
