car bounces when start help!
i think my flywheel needs resurfacings......when i start in first gear....and go it makes a scatching noise....and den most of the time i cant start off smoothly and when i try to creep my whole car bounces up and down real bad....its weird...what can it b....flywheel......motor mounts......axles.....help
99ex with b16a swap
99ex with b16a swap
Unceasing Measure
Re: car bounces when start help! (Ryceboi318)
throwout bearing/pilot bearing might be done, clutch might be done, flywheel might be done, motor mounts are probably done anyway. You'll have to crack it open one way or the other...might as well make this post after you're done doing so.
What kind of clutch/flywheel setup do you have? Is is aftermarket race/street? That might be the problem.
I have that problem. I have a three puck race only clutch and toda lightweight flywheel. It's a bitch to drive sometimes.
Good luck getting everything worked out.
gaydm.accord
04-29-2005 05:28 PM
