integra trailing arms for my 94 coupe... some help please.
I got some integra (94-97 rs) trailing arms and 40/40 prop valve for my 94 coupe and I was just wondering because I've come across conflicting information while searching and I'm looking for the concrete answer to my question: I don't have the e-brake cables, plus I'm a lazy **** so instead of replacing both trailing arms can I just replace the brake/hub assemblies? if I just change that will I still have an e-brake cable issue? I have the integ soft brake lines, so I'm ok there it's just I cannot find integ e-brake cables any where and it's bloody expensive new, plus changing just the hubs seems like an easier fix.
#1 Super Guy
Re: (B16EJ)
Drum Cables will NOT work with rear discs (if that is what your asking). If you swap out the spindles, the only thing that saves you from is having to remove & replace your whole trailing arm.
I am not sure which rear disc E-brake cables work the best on a coupe. Mabey sombody else could help out...
Armada
04-20-2010 06:48 AM
Just Bought Rear Disk breaks for My 94 Civic Coupe will I need new E-Break Cables and Break Lines???
dj theoretic
07-08-2008 05:19 PM
