simplilist question ever...
...its cold like ***** outside so i didnt look under my car yet but...do you need to take off the header to be able to take off your oil pan? o and how much do you think an oil pan gasket will cost?
Re: simplilist question ever... (tyranosauras-rex)
if you have the oem exhaust, or a dc header 4-2-1 you just take off the lower part of the exhaust not the part that connects to the head.
so your not necessary taking the entire header off. unless you have a one piece 4-1 setup.
being you are in WI even if you have a 2peice header, the bolts to disconnect it in the middle are probably hella corroded. i would just take it off the head good luck
