obd2-obd1....chipped p28
I have a 00 civic with with 96 jdm itr engine....anyways, im currently running a 00 p73 ecu obd2....everything seems to operate correctly with the exception of having the cel on becuase of the remove immobolizer. Well anyways, I bought a obd2b ecu jumper and bought a custom mugen spec p28 ecu. Now when I hook it up, my rpm would flucuate from 100-1200 rpm. what could be the problem? I cleaned my iacv and check all hoses and seems fine. I then tested the ecu on my buddy 95 teg and everything operates correctly on his car....if anyone could give me some advise, I would greatly appreciated...thanks...
Re: obd2-obd1....chipped p28 (CNSK)
did you reset the ecu? did you let it idle for 5 min without pressing gas pedal or turn on any accessories? if it work on your friend car fine the you should check the fitv.
fitv? I did reset the ecu...and let it idle for a over 10 min....still flucuates.....plus I adjusted the throttle needle and seems to just rev up and down even higher...from 100-1500.....I dont know.....could be some leek hoses somewhere that i couldnt find...any more suggestions....thanks
fitv = fast idle thermo valve. you need to set you tps back to spec. .45v at idle and 4.5v wot. check your throttle cable to see if it is too tight.
mikeunreal2
31
03-12-2006 10:28 PM
