B16A Vs B16B CrankShaft ??
Re: B16A Vs B16B CrankShaft ?? (Ratman)
i believe the specs and stroke are the same...i dont see how they could be any different.
if the bore is the same and they are both 1.6 liter, than they are the same.
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED »</TD></TR><TR><TD CLASS="quote">NO it will not, the B16B has a taller deck height than a B16A, a B16B block is just a destroked B18C5 block</TD></TR></TABLE>
correct. to back the above poster up, the timing belt is the same part # for both the b16b and the b18c, wheras the b16a belt is a different part # (shorter)
Re: (THEUSED)
Just cause they have the same displacement it doesn't mean they're alike. R/S is totally different in the B16B than the B16A.
Re: (james p.)
i was referring to the crankshaft similarities, not if the stroker kit will fit or not. my bad.
he asked any differences in the crankshaft in the first question.
Re: (james p.)
hmm, so it is not posible to take the GSR Crank,rods and pistons,
and mount them in a B16A2.. damit
then the primary reson for the diffrence must be the length of the rods,
becaus the stroke is the same in B16A2 and B16B, but yes, it seems the
deck height is not the same..
this must alsow mean that the B16B Block, is the same as B18C blocks
mkinpwrat12g's
11-15-2006 07:54 AM
gulftiresinc
12
08-14-2004 10:39 PM
Unsung
06-16-2003 05:38 PM
