Can a Eg civic hatch pull a small Trailer if i get a h22 swap?
Hi i have a eg civic hatch and em wounding if its possable my car could pull a small trailer if i got a h22 swap? im asking this because i work contruction and do alot of side work... In the trailer i would be puting stuff like shovles,sand bags and cement bags, wheel barow, tool boxes lil bit of bricks some days stuff like that? i noo the h22 has alot of power but can the civic handle a trailer? would the frame be alright.
i noo some of u pll might say just buy a truck but i was planing on doing a enigne swap on my car anyways. and also with buying a truck it will cost me more moeny and will have to pay more insurance for both cars... ? Is my idea possable?
Re: Can a Eg civic hatch pull a small Trailer if i get a h22 swap? (ted)
i dont see why not... weve pulled other cars back with a chain or rope when they broke.
Chris
Chris
it should be able to. i remember seeing a picture that somebody posted of their car w/ a trailer.
i dont care about gass i bet a truck would take just *** much gass. i guess i would need better brakes? im realy serious about this.. can u please keep giving me your ideas thanks
Re: (numbnuts22715)
I pull a trailer with my Del Sol stock engein stock suspension, It has 4 rces ties and a tool box that is about half full with tools jacks and other misc stuff. I harly know the trailer is there. I have the 48inch utilty trailer from northern tool.
Re: (Solracer)
A while back in the EF forum some guy in a civic DX stock towed an old school prelude, with a full 5 car load in the dx, and the only problem he had was heat on the brakes.
https://honda-tech.com/zerothread?id=1058438
So, in response to your question, yes.
You may be able to pull a small trailer but it would be unsafe to use it. If you are speeding down the freeway and you have to come to a fast stop your car and trailer will go flying.
Re: (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">You dont need an h22 swap to be able to tow.
Just make sure the current engine is healthy.</TD></TR></TABLE>
Obviously if you have a 70hp CX that's out of the question.
The engine isn't the problem when towing, it's the transmission you have to worry about, and also the brakes. Also you need a good hitch.
For the money of a swap you could be a truck to haul your **** around.
Re: (madtownhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayinMoscow »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
Yes it will pull a trailer fine. I towed my friends integra in my Stock Cx hatch....I wasnt hauling *** or anything but it worked. With an h22 you wont have any issues. I would just buy a beater truck if i were you though instead of using a hatch as your work truck.....my .02
.</TD></TR></TABLE>
You can even with the stock CX. Problem is your brakes are going to fry during hard stopping. Another problem is the chasis. Hatches weren't designed to be a tow car. You would have to ghetto rig your rear bumper and reinforce the subframe. The money you'll spend converting the hatch into a tow car could buy you a compact truck.
Its your choice but if you ask me, I wouldn't recommend it.
Re: Can a Eg civic hatch pull a small Trailer if i get a h22 swap? (K I T T)
Im not saying i had a tow hitch on my hatch....i used tow straps and strapped them to the tow hooks. Thats how i moved the integra. I have seen 2 or 3 hatchbacks with tow hitches on the back though.....looks like ***.
Re: Can a Eg civic hatch pull a small Trailer if i get a h22 swap? (94_HATCH)
Towing another car is different from towing a trailer.
Towing another car wont put load on the brakes since the car being towed also has brakes. Towing a trailer on a tow hitch puts the load on the brakes of the car since the trailer wheels are on free wheel. Not unless you ghetto rig the brakes that will make the trailer wheels brake as the car brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_HATCH »</TD></TR><TR><TD CLASS="quote">hatchbacks with tow hitches on the back .....looks like ***.</TD></TR></TABLE>
Mr. Badwrench
the original owner of my car pulled a small sail boat with the si till i bought it, then i toook off the trailer hitch. he did it with the d16z6 no problems. still had the original clutch also.
Re: (Blazin Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic »</TD></TR><TR><TD CLASS="quote"> I've seen a stock 95 EX pull a pair of waverunners so i'm sure it will be more than fine if you don't mind a hitch on the car.</TD></TR></TABLE>
I've seen this exact same situation...
I think you'll be fine as long as you keep the trailer weight low. The biggest problem is the strength of the subframe where the hitch has to mount.
