92-95 civic head lights (how do u open them up?)
dose any one knoe how 2 open up 92-95 civic head lights????
i heard u stick them in the oven but i donno how long or on wut temp???
or if there is any other easy way of doing it ????
Re: 92-95 civic head lights (speedhawaii)
200 degrees for 8 minutes. Pull them out start to pry them apart then pop them back in for another 4-5 and keep going.
Only easier way I can think of would be to get a heat gun (REAL heat gun not a blow dryer set on high), and heat up the glue stuff.
Re: 92-95 civic head lights (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">200 degrees for 8 minutes. Pull them out start to pry them apart then pop them back in for another 4-5 and keep going.</TD></TR></TABLE>
I did 250 for 5 minutes, you get the idea. I just kept checking on them until the glue got soft
Re: 92-95 civic head lights (Uncle Ben)
I did 350 or so but just check on them as stated above!
Also be careful not to break the glass be sure to remove the metal clips also the plastic on the headlight is going to be soft so be sure not to bend the brackets!
Re: (jeffk182)
haha open them up 2 make the inside black
0o0o0o0o yah i got sum vison clear corners is there any way i can get thos open dose any one knoe how fo do dat???
Re: (speedhawaii)
Hey , the corners are alittle more difficult but it's the same way as the headlights...The reason is that the corner lights lences are made of plastic and the edges are hard to pry open with out cracking the lence. also another tip is use some silicone around the edges, just incase so no moister gets in..... P.S Why you close your shop at the Queen Kaahumanu Mall in Maui ?
Re: (jeffk182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffk182 »</TD></TR><TR><TD CLASS="quote">He's asking, what are you trying to do?</TD></TR></TABLE>
thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedhawaii »</TD></TR><TR><TD CLASS="quote">haha open them up 2 make the inside black
0o0o0o0o yah i got sum vison clear corners is there any way i can get thos open dose any one knoe how fo do dat???</TD></TR></TABLE>
post pics when you are done...i'd like to see
thank you
Moms 94
01-05-2013 03:18 PM
