still having wheel hop after traction bars =(
1 Post
i have an LS motor in my 95' civic coupe. my car didn't wheel hop at all after the swap, but it started doing it after 2 weeks after the swap. i have ES motor mount inserts, nrg engine damper, and l-con traction bars. i don't wheel hop as much, but i still wheel hop to the extent where it could possibly damage something. i was told that it could could be my axles? suggestions please!
Re: still having wheel hop after traction bars =( (itsJDMyo)
the traction bars need to be tight aka having a load on them, otherwise they wont do jack ****
might want to try and get new suspension bushings, but those are a pain in the ***, i havent heard anyone with wheel hop issues after traction bars are installed, sry i couldnt help more
Re: still having wheel hop after traction bars =( (Soccerking3000)
like just said, look into your ball joints and your bushings. They probably need replaced.
A new set of ES bushing for the entire suspension is only like $120, its just some time involved to put them all in. A few are a bitch to get out but can be donw.
Ball joints are pretty cheap too. But most likely its the bushings.
Re: still having wheel hop after traction bars =( (core3200tm)
how are your motor mounts? solid? how are your axles? this can also cause wheel hop.
1 Post
Re: still having wheel hop after traction bars =( (litterbox)
my tires are good. they are khumo 711s. still a good amount of tread left. my alignment is also good. had it done a few months ago. my motor mounts are still very good (engine does not move at all when i rev). and i tried preloading the clutch, but when i shift from 1st-2nd, it still wheelhops. i'm just hoping it's my axle, i'll try getting that replaced next week
khumo suck imo ! but i think try dropping tires pressure might help a little - and the suspensions bushings as every one is saying will help
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo »</TD></TR><TR><TD CLASS="quote">my tires are good. they are khumo 711s. still a good amount of tread left. my alignment is also good. had it done a few months ago. my motor mounts are still very good (engine does not move at all when i rev). and i tried preloading the clutch, but when i shift from 1st-2nd, it still wheelhops. i'm just hoping it's my axle, i'll try getting that replaced next week</TD></TR></TABLE>
Your magic LS doesn't make as much HP or torque as my I/H/E/MSD GSR motor and I can both launch and shift at redline from 1 to 2 without it hopping the wheels. Oh, by the way: I don't have motor mount inserts, an "engine damper" or traction bars...and I do it on mismatched Winter tires .
Don't drop the clutch. Period. If you feather the clutch at the launch and on the 1-2 shift, you won't wheel hop. You'll get better E.T.s and you won't destroy your suspension and/or driveline components. It's not your suspension or damper setup: it's your driving. End of story
Re: still having wheel hop after traction bars =( (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Don't drop the clutch. Period. If you feather the clutch at the launch and on the 1-2 shift, you won't wheel hop. You'll get better E.T.s and you won't destroy your suspension and/or driveline components. It's not your suspension or damper setup: it's your driving. End of story </TD></TR></TABLE>
You will def. figure this out after owning an awd lol
ghostsi69
Suspension & Brakes
13
12-03-2005 12:58 PM
