help please b16a2
help please b16a2
I have a problem last week I spraid a manifold cleaner and all of a sudden my car died out then I turnd it back on it started to make that noise like it was a vaccum leak,I thought it was becouse I spraid way too much that I shrunk my trottle body gaskit I even replace the gaskit and a new pcv valve ,and double check all the wires I have a b16a2 so please help.......
Re: help please b16a2 (hnz28sjz)
Other than the noise, how is the car running and how is the idle.
Sinking the gasket is unlikely for the intake manifold or t-body gaskets , but maybe the injectors.
The O-rings are a rubber style gasket which certain chemicals MAY damage.
You may want to try to re-seat the injectors seals. Take off the rail, take out the injectors and spray the seals LIGHTLY with white grease, or spray it onto your finger, then rub it on. This may help.
Re: help please b16a2 (jdmcars.com)
My car is running fine it idles at 1000 so far its running fine it goes from 1thou to 2 thousand I was thinking it might be my t-body sensor but no engine checklight is on. Anymore advice
