Are there any links on how to bleed coolant??
Re: Are there any links on how to bleed coolant?? (lowRIDAH)
uhhh just run the car with radiator cap off till no more bubbles are coming up through it. You can also (what i do) is just open the bleeder on the upper radiator hose right next to the block and fill the radiator up utill it flows out of the valve not just drips, tighten it up, put the radiator cap on and be done with it.
Check for a drain plug on the bottom of the radiator. You might have to remove the plastic cover.
Re: Are there any links on how to bleed coolant?? (spoonracer84eg)
There's a great write up with pics in the repair manual. Damn people it's only $15 and it has torque specs, fluid capacities, and answers all the basic questions.
ILcrxsi1
03-29-2007 03:14 PM
