Car quits, will crank but not start
I have been having tyhis prob for a while
My car dies at any giving time while driving and wont start for about 2 hours (maybe more) thought it was relay but not sure now napa only sells 2 relays on internet fuel and headlight. and ideas what it might be
Thanks for the help
Thanks for the help
main relay would be my guess... get a friends relay and test it out. its also known as fuel pump relay.
what vehicle do you own?
do you have any air fuel hacks like a vtec controller?
btw should look like this...
http://cgi.ebay.com/ebaymotors...ZWDVW
but certain vehicles have diff relays make sure you get the one acording to your make and model.
Re: Car quits, will crank but not start (thegrenone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegrenone »</TD></TR><TR><TD CLASS="quote">
My car dies at any giving time while driving and wont start for about 2 hours </TD></TR></TABLE>
Does it have spark when it's acting up? A main relay rarely causes a stalling problem.
I had a similar problem, with my car running and than just dying while driving down the street, and than it would start back up and 20-30 min later it would die again. But my RPM gauge was going haywire, so i replaced the ignitor....Never had the problem again
Re: Car quits, will crank but not start (DSoDry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSoDry »</TD></TR><TR><TD CLASS="quote">Same problem on my hatch, ended up being my rpm signal wire going into my ecu was loose</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Same thing happened on my car. Turned out to be a bad dizzy.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWANTAHB »</TD></TR><TR><TD CLASS="quote">I had a similar problem, with my car running and than just dying while driving down the street, and than it would start back up and 20-30 min later it would die again. But my RPM gauge was going haywire, so i replaced the ignitor....Never had the problem again</TD></TR></TABLE>
My car wouldnt turn over a lil bit ago. Had no clue what to look for. Just happened to grab the starter ground and it was loose. Started right up. Its a painstacking process to find out whats wrong.
SpoolinEK9
03-15-2005 04:25 PM
LilMissCrystal81
11-19-2004 11:26 AM
