cx swap
Old 03-25-2006, 03:05 PM
2DoorBandit's Avatar
Default cx swap
hey guys im lookin to buy a 92-95 cx and put my d16z6 in it out of my ex (that is toteled do to people not stop at red lights...( is this going to be a plug and play swap or do i have to wire anything in
Old 03-25-2006, 03:28 PM
Lewy. Dee Ayy's Avatar
Default Re: cx swap (2DoorBandit)
i kno ul have to wire it for vtec..so take the ex wire harness with the motor as well
Old 03-25-2006, 03:30 PM
Default Re: cx swap (WhiteOut)
even if i use the ex engine harness and ecu i still have to run wires for it
Old 03-25-2006, 04:53 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit &raquo;</TD></TR><TR><TD CLASS="quote">even if i use the ex engine harness and ecu i still have to run wires for it</TD></TR></TABLE>
This is true.
Unless its a '92. Then the main harness is pre-wired for vtec.
Otherwise you will need to run two wires for the passenger strut tower into the ecu plugs.
Old 03-25-2006, 05:17 PM
Default Re: cx swap (Slopoke)
so 92 cx's come wired for vtec
is this for every 92 civic also
Old 03-25-2006, 05:49 PM
Slopoke's Avatar
yep
Old 03-25-2006, 07:33 PM
IOSUA's Avatar
all you have to run is 3 wires. 1 ground and 2 to the ECU. its really easy. good luck
Old 03-25-2006, 08:00 PM
Default Re: cx swap (jdm dc2 01)
will i have to run anything for a knock sensor or 02 sensors?
Old 03-26-2006, 11:34 AM
IOSUA's Avatar
i dont think the CX motor has a knock sensor. but im not too sure.
Old 03-27-2006, 05:36 AM
if i use the ex engine harness do i need to run the ground or just the solinoid and pressure switch+
i already pullled the wires out of my ex that run to the ecu but i only pulled two not the ground
T-RO
08-06-2008 03:10 PM
Doeboy
11-18-2004 09:31 PM
(Civic_Duty)
10-19-2004 04:51 PM
LDxShyGuy
06-01-2003 11:07 PM
itr0032
11-20-2001 04:31 PM
Quick Reply: cx swap
