Type R head on a b16a?
Does anyone here have or know someone who has had experienced a type r head on a b16a bottom end with CTR pistons?
Thanks
Thanks
Re: Type R head on a b16a? (Padawan)
If it makes a considirable amout of more power!!! I can get a pr3-2 ( B16B) head with it's intake manifold and TB plus that it's S4C trany and was wondering what kind of number I could excpect from it if I put 81.25mm CTR pistons!!! ( head is stock internals)
Re: Type R head on a b16a? (EJ8 DAVID)
That would be more then a stock b18c5!!! Do you know of anyone who has done something similar and gotten good results?
Re: Type R head on a b16a? (psegs80)
ive seen some one put type r head on b16 block, but im not sure what pistons he used. Im pretty sure he got around 170whp, but not to sure. His name on here is JDMLYFESTYLE i think
he has a website too. JDMLYFESTYLE.com i think.
1 Post
I personaly wouldn't waste money on an ITR head if you already have a B16 head. As was stated before the differences are dual intake valve spings and MINOR hand polishing of the runners. For the price, you could upgrade the valve train of your PR3 head you already have and make more power than the mild gains you will get by spending a fortune on an ITR PR3 head.
By buying the one off of a C5 motor, you are paying for the name when you already have the same cast head.
1 Post
Man there is NO best B head honestly. The PR3 is the casting, B16a, b, and B18C5 are all PR3 heads. The -2,-3, and so on are just series or something of that nature, I can't remember off the top of my head but you can search and find out if it bugs you that bad.
It honestly sounds to me like you are just itching to either A spend a crap load of money or B just be able to say "I have an ITR/CTR head on my ride". If that is what you are doing, then just go for it. Otherwise, do like I stated before and spend the money on springs, retainers and a set of cams for your current PR3 head and outflow both of them. The hand polishing may be worth 5 more CFM (whoopie) and the dual intake valve springs are taken care of by an aftermarket set of springs and retainers. Last but not least, ITR/CTR cams are kick *** but there are better out there and you have the option of doing that if you just build your current head WHICH FOR THE LAST TIME IS A CTR/ITR CAST HEAD!!!!!!
Get it now? It would be a waste spent for a name. If you still want to, go for it.
Re: (Jay_Sensing)
Thanks man, the thing is that the trany which has ATS 3-4-5th gears, the Intake man + TB and distributor and a p61 ecu come, AEm feul rail+ pressurre regulaor, Toda Flywheel a a stage 3 clutch come with the deal, for 6000$ canadian I have all this, an a b16a block bored + 0.010", blanced crank and a CTR n1 pulley + dyno tuning by remaping the ecu with Chrome data. In Canada a b18c5 swap is 4500-5000$ and to get a b16a head do the work to it and buy the I.M. + trany is most likely in the same ball park!
It's no money that's I'm concerned about, it's performance gains!
Thanks for the imput
1 Post
Damn bro, you just confused the **** out of me with that last post lol. So you already have the
"he trany which has ATS 3-4-5th gears, the Intake man + TB and distributor and a p61 ecu come, AEm feul rail+ pressurre regulaor, Toda Flywheel a a stage 3 clutch come with the deal, for 6000$ canadian I have all this, an a b16a block bored + 0.010", blanced crank and a CTR n1 pulley + dyno tuning by remaping the ecu with Chrome data"
And you are just looking for a head?
If so, then you may still be cheaper going to aftermarket way. Thing I am still wondering is what you have now and what you are trying to accomplish in the end.
Re: (Jay_Sensing)
Lol no dude, A guy wans to sell me a stock b16b head, intake manifold and TB with p61 dyno tuned with crome ecu + distributor, S4c type r trany with ats gears, a toda flywheel and stage 3 4 puck clutch, aem fuel rail + presure regulator and a CTR n1 crank pulley with tuning for 5000$ then I can get a b16a block that I have bored +0.010", get the crank assemblyt balanced, ctr 81.25mm pistons new bearings and gaskets for arround a 1000$ ( can.$) so total would be arround 6000$
I was posting up to see if type r head on b16a was good motor combonation??
Thinking of upgrading the cams???
Thanks for trying to save me some $$$
I think it's a great deal just wanted to see how good of a motor it would be!!
Re: (psegs80)
with 6k you can build a motor that puts out 200whp+. just start from scratch. get a stock head and send it out to get it ported, get valvetrain, some nice cams, and get the block built. i spent around 4500 on my LS VTEC and i put down 217whp and 139tq
MotorMatrix.com
03-03-2003 11:53 PM
