Widest tires possible
Re: Widest tires possible (professor poon)
Generally run no more than 20mm wider than original stock, no more than +3% bigger in overal diameter, and stick with your original offset and you should be fine.
Concentrate on getting better tires not wider tires.
Re: Widest tires possible (old man neri)
there is a new 235 wide tire that a few boosted people are running with spacers up front. This is for serious street tire traction issues though and I dont know if they fit on the rear becuase ive only seen people use them up front.
Re: Widest tires possible (94_HATCH)
Damn! A 235 tire on a civic!?!?!? That's one helluva setup. I run a 205 with no rubbing issues. Always thought about trying a 215 though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">Generally run no more than 20mm wider than original stock, no more than +3% bigger in overal diameter, and stick with your original offset and you should be fine.
Concentrate on getting better tires not wider tires. </TD></TR></TABLE>
I plan on getting better AND wider tires...
