95dx motor in 93dx
Banned
95dx motor in 93dx
ok so i was putting my stock 1.5 out of my 95dx into a 93 dx auto.. converted it stick and all... i have had to problems...the axles dont seem to fit right.. they dont look long enough and they poped out and the car does not move.. and also the tranny mount angles up instead of straight out.. i found a temp fix for that but was wondering what axles to use?? the auto axles wont work will they? i really dont feel like going out and buying new axles
Banned
Re: (sohcvtec1995)
no, i didnt get the conversion mount... i just used the one off the 95.. im still confused about the axle situation tho.. i can sit there in gear and rev it up... car does not move but the speedo goes up normailly.. i know the trans is good.. the axles didnt look like they sat all the way in the trans
Re: 95dx motor in 93dx (slo_go_civic)
The manual and auto CV axles ARE DIFFERENT...
thats one
two, did you go from a coupe or sedan to a hatch? I THINK not sure, that there is a different.. in which case you need to use the CV Joints from that model, but manual not automatic...
Try your CV joints from your other dx, the manual one, why would you try to use cv joints for an automatic on a manual?
Whatever, either way, i know for a fact they ARE DIFFERENT!
thats one
Re: 95dx motor in 93dx (95dxb18c1)
use the 5spd axles, also the motor will not sit in the engine bay correctly if you do not have the proper upper transmission mount. i got mine from placeracing.com
