Will these rims fit?
Re: (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A »</TD></TR><TR><TD CLASS="quote">Why don't you just try to put them on? It doesn't take long to put them on and try them out.</TD></TR></TABLE>
Re: Will these rims fit? (eXplicit)
Stock for your car is 185/65-14
215/40-17 is only 1.3% bigger that stock in overal diameter which is acceptable however it is 30mm wider. This may lead to rubbing. It's hard to tell. Generally one trys to stay within 20mm of stock. 205/40-17 would be a much better size for your Honda.
It is very hard to say if those tires will rub or not. Also what is the offset for these rims. That will make a big difference. And ya, of course the bolt pattern as someone else mentioned
Cheers.
Cheers.
Re: Will these rims fit? (old man neri)
Yeah well I didnt have the rims as of that first post, I wanted to find out before I got ahold of them, yes they fit, and yes they rub, only in the back everytime you hit a bump it is a tad bit too wide. You were right neri thank you for the information.
Cowtit
05-06-2003 10:00 AM
Greyout
02-17-2002 05:06 PM
