sleeving?
sleeving?
Im boreing a LS block to 84 mm I was just wondering is it necessary to sleeve the block... its going to b all motor no boost LS VTEC
1 Post
Re: sleeving? (hondachris1994)
a stock sleeved LS block cant be bored out to 84mm. the max you can do and thats already pushing it is 82mm. The safest bore size that you can do Max on stock sleeves is 81.5mm
If you are doing 84mm, you HAVE to sleeve it.
Re: sleeving? (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">a stock sleeved LS block cant be bored out to 84mm. the max you can do and thats already pushing it is 82mm. The safest bore size that you can do Max on stock sleeves is 81.5mm
If you are doing 84mm, you HAVE to sleeve it.</TD></TR></TABLE>
What he said and also what is your intended boost levels?
nickgmiller04
12
03-26-2004 04:07 PM
