Oil pressure sensor d16y8
I need to kno where i can check for my oil pressure on my 97 civic ex d16y8 b/c i just boosted it and now it has really low oil pressure. I was told that it was on the back of the block above the oil filter but i cant find it or its in a different spot any help or opinions would def help thanks
Re: Oil pressure sensor d16y8 (MBlake55)
It's above the oil filter on the back of the block. There is a black rubber grommet that covers it up.
Where to you give the turbo it's oil supply if you didn't tap into the oil pressure sensor?
Re: Oil pressure sensor d16y8 (EX-T)
fresh oil comes from the oil sandwich adapter btw/ the block and the oil filter thanx for the input p.s. if i run my stock cat will that take away a lot of power b/c of restriction? thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MBlake55 »</TD></TR><TR><TD CLASS="quote">fresh oil comes from the oil sandwich adapter btw/ the block and the oil filter thanx for the input p.s. if i run my stock cat will that take away a lot of power b/c of restriction? thanx</TD></TR></TABLE>
Yes, the stock cat will restrict power. Just curious, what kind of turbo kit are you running?
You probably can't see the oil pressure sensor b/c of the sandwich adaptor. It probably sticks out further than the sensor does so it's blocking your view.
ya thats prolly tru i gotta take a better look at it b/c its at my buddies shop right now and i only get over there as much as i can too look at it thanx for all the help tho and the input
92accordEX4life
01-17-2006 05:30 PM
