ECU chipping question already searched?
Guest
Posts: n/a
Hey guys ive looked around and searched on ECU chipping and i so i bought the Phearable kit - Now im looking to install it and am a little bit confused- I know were the chips go but where do the 2 capaciters go? Ive looked at the tutorials but they are not helping too much any input>
Five is on the far left were it says c51, next to the 74hc373 latch chip.
Seven is on the bottom left were it says cn2, only fill up pins 1-4 with it, which are the 4 to the left.
Re: (AlienKrOZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ »</TD></TR><TR><TD CLASS="quote">does this kit require soldering?</TD></TR></TABLE>
Yes, all kits require soldering.
It's not hard, though. As a noob I picked up some junk boards from my job and practiced soldering/desoldering. I figured it was fairly easy so I went ahead and chipped my own ECU.
Re: (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">Yes, all kits require soldering.
It's not hard, though. As a noob I picked up some junk boards from my job and practiced soldering/desoldering. I figured it was fairly easy so I went ahead and chipped my own ECU.</TD></TR></TABLE>
Yes, it is very easy to remove the sleeves with too much heat. Try using anything under a 30 watt gun/iron.
Re: (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">Yes, it is very easy to remove the sleeves with too much heat. Try using anything under a 30 watt gun/iron.</TD></TR></TABLE>
I think the one I used was a 15w one from RadioShack.
BTW- Spend the few extra dollars on the mechanical vacuum style solder sucker vs. the braided copper. Much easier to work with and much faster.
basiceg6
11-27-2009 09:45 AM
