Big problem
Big problem
I just bought a 1998 civic si(canadian). The car has been swapped to manual and also has a B16A2(USDM) I need help with the drivers and passanger side shafts.
Transmission in the car is a Y80(after searching dunno if it is gsr )
Please I need help.. I also need to know where to get a secondary o2.
I am going to post pictures later once I get the car home from my uncles shop
Also I need to know if any one knows where I can get a stock cat-back system and cat for a decent price..
Thank you in advance
Modified by johnny_tdi at 7:17 AM 4/30/2006
Modified by johnny_tdi at 7:42 AM 4/30/2006
Re: Big problem (B.)
Both boots on either side were ripped. There is all grases or whatever all over the hub assembly and controll arm..
Let me explain what shfts do I need to buy gsr/sir/typer whatever that will fit properly and solve my proble with my saftey
Modified by johnny_tdi at 7:41 AM 4/30/2006
400 HP Club
why would he needs a new intermediate shaft??? his car is already swapped, just the outer cv boots are busted. OP, all you need is new axles, depending on which intermediate shaft you have depends on which axles. most likely though any 94+ Bseries axles.
400 HP Club
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">why would he needs a new intermediate shaft??? his car is already swapped, just the outer cv boots are busted. OP, all you need is new axles, depending on which intermediate shaft you have depends on which axles. most likely though any 94+ Bseries axles.</TD></TR></TABLE> who knows what he needs man, I was just trying to point him in the right direction......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B. »</TD></TR><TR><TD CLASS="quote">gsr shafts will be fine to use.. Just make sure you get the intermediate shaft aswell.. </TD></TR></TABLE>
sounds like to me you are saying he NEEDS the intermediate shaft. in his original post he states the problem is busted outer cv boots, which has nothing to do w/ the intermediate shaft. the only problem he could have w/ the intermediate shaft is being bent, or the bearing being bad, and the bearing can be replaced, so you arent pointing him in the right direction at all.
Re: Big problem (schardbody)
can I use a si(sir) shaft on both sides or do I need a gsr shaft because of the y80 tranny.. also I need to know where I can get a decent price on a secondary o2 please as well as a stock full exhaust system because the car has a ricer reactive muffler..
sorry cant post no more noob thank you all for you help
Modified by johnny_tdi at 6:36 AM 5/1/2006
secondary o2 can be got at any parts store, just get a universal 4 wire o2. depending on which intermediate shaft its got depends on which axles you get. most likely any 94+ dohc civic or integra axles, if not then its gonna be 90-93 integra axles.
Re: Big problem (johnny_tdi)
I have the stock exhaust from my 98 civic. I had the stock piping cut to fit the header for my GSR swap, and there is a highflow cat. I think that it would work for your car, only problem is I am in NY
