Integra dash wiring one wire left (searched found nothing about my problem)
Now with pics- integra dash wiring one wire left (searched found nothing about my problem)
ok i went the easy route and i use the integra harness with the civic clip but on the integra grey clip there was no leftover yllw/blk wire for the signals but i did find it on the green clip and it is right next to the yllw wire that its supposed to be connected to to get the blinkers working should i remove it and tap it to the yllw wire or is it in the right location its right next to it and in the charts i found it says connect the leftover yllw/blk wire from the grey clip but mine is already on the green right next to the yllw anyways i guess ill stop rambleing on any help will be greatly appreciated
p.s i would just like to state that ive been through all the links and i found nothing about my problem dont wanna seem like im not trying but everyone else seemed to have a yllw/blk wire left over from there grey clip but i dont also if it helps its a 96 ls 5 speed dash and its going in an eg thanx again
Modified by ATX45 at 3:58 PM 4/30/2006
Re: Integra dash wiring one wire left (exotik4doorcivic)
ok but the problem on mine is that there was no yellw/blk on the grey clip its already on the green clip and its right next to the yllw wire that it should be connected to should i tap it into the yllw one ? thanx
got some pix kinda shitty my cam is cheap
this is the grey integra clip the only yellow wires on it are ylw/silver dots and ylw/grn
this is a pic of the integra green clip with the ylw/blk right next to the solid ylw
i have the civic grey clip and im going to swap it out with the integra one but i wanna figure out my blinkers first so i can have everything correct before the install well thanx again
Modified by ATX45 at 3:52 PM 4/30/2006
cool thanx ill read through his thread again
yea well i guess im working with a obd2 harness so ill have to find a writeup for it hopefully someone who has done it will chime in thanx for the help fellas
Modified by ATX45 at 6:19 PM 4/30/2006
searched around and cant find anything about using the obd2 harness anyone know if it works the same or not i matched up my clips to the ones in litterbox's writeup and everything looks the same except for my yllw/blk wire is in the green clip right next to the solid ylw wire instead of being on the grey other than that they match up locations and all
Re: (ATX45)
on the grey clip you look for the black wire with the yellow line (as stated above)
and splice in into the solid yellow wire on the green plug
ah ok i had it backwards but i just checked and tha blk/yllw stripe is also on the green plug should i tap it to the yllw and will i be fine or will i need the obd1 harness if you look in my picture above you can also see the black wire with the yllw stripe on the green clip
Re: (ATX45)
as far as i know yes that is what you would use, the black wire is always on the grey plug though the wires shouldnt be different, but i could be wrong,
check your hazard switch and make sure there is a black wire with a yellow line and if there is then i would try splicing both wires from the that green plug
redman223
Audio / Security / Video
07-10-2004 07:34 AM
