Leaking oil
Leaking oil
Ok so the problem is i had a blown head gasket so i changed it and got the head resufaced just to be safe and when i started it it began to leak oil under the vtec solinoid where the head and the block meet i know i torque the head right to correct ft/lbs an sequence so can anyone help
i replaced the dizzy o-ring and cam plug before oil stop showing up on that corner of the block, if any gasket on that side of the head is leaking it will end up there, or worst case your block is warped
Re: (egsleepercivic)
I just replaced the dizzy an cam seal 2 months ago so its not that im going to have to thake the head off and check the block
did all that work and couldnt even take a straight edge and some feeler gauges to the block? i quess you used old head bolts too?
how did you prepare or clean deck before putting new gasket and head back on?
Re: (tatmark1)
Yes i now i fucked up by not checking the deck i just cleaned it an i did by new head bolts, but not that much oil comes out
saemoonyang
12
06-07-2010 02:01 PM
pooRmansss
02-19-2009 03:24 PM
