lsd for $300
Imperious: Mod of Valor
Re: lsd for $300 (blueR87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueR87 »</TD></TR><TR><TD CLASS="quote">is it worth it to buy the factory lsd for $300 when i buy a jdm engine?</TD></TR></TABLE>
It depends. What motor are you getting? What car is it going into? If you're just going to daily drive the car and have the motor for a bit extra go, than no. If this is going to be a track/drag car, than yes I would invest in an transmission that comes with a limited-slip differential.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueR87 »</TD></TR><TR><TD CLASS="quote">im gona get the b16a2. i would be using it for track use as well. I just wanted to see if people actually get it. </TD></TR></TABLE>
If the car is going to be used for the track use and you're planning on modding that motor than yes, I would get the LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueR87 »</TD></TR><TR><TD CLASS="quote">aight koo thanks for the info. </TD></TR></TABLE>
No problem, I'm here to help. What are you planning to do to your b16a2? What's your budget look like? Is this car going to be daily driven?
Re: lsd for $300 (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">
No problem, I'm here to help. What are you planning to do to your b16a2? What's your budget look like? Is this car going to be daily driven?</TD></TR></TABLE>
my budget right now is just for swap. im going n/a with the b16a2. planning to get bolt ons then cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueR87 »</TD></TR><TR><TD CLASS="quote">my budget right now is just for swap. im going n/a with the b16a2. planning to get bolt ons then cams.</TD></TR></TABLE>
What kind of car do you have now? With what motor? If you're running a d16z6/y8 motor, you'll find that the b16a isn't much better than motor you currently have. If you do have one of the said motors, I would possibly look into boosting the motor. You'll find that D series with boost can be quite the contenders against those with DOHC motors.
What kind of car do you have now? With what motor? If you're running a d16z6/y8 motor, you'll find that the b16a isn't much better than motor you currently have. If you do have one of the said motors, I would possibly look into boosting the motor. You'll find that D series with boost can be quite the contenders against those with DOHC motors. </TD></TR></TABLE>
i agree. i have a eg cx right now d15b8 if im not wrong. and the engine is no good anymore, it burns everything. a reason for me to swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueR87 »</TD></TR><TR><TD CLASS="quote">i agree. i have a eg cx right now d15b8 if im not wrong. and the engine is no good anymore, it burns everything. a reason for me to swap </TD></TR></TABLE>
Perhaps, if you want a little more power.. You may consider getting a JDM GS-R motor (b18c) this motor is substantially faster than the b16a2.
Perhaps, if you want a little more power.. You may consider getting a JDM GS-R motor (b18c) this motor is substantially faster than the b16a2.</TD></TR></TABLE>
thought about it but not enough money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueR87 »</TD></TR><TR><TD CLASS="quote">thought about it but not enough money. </TD></TR></TABLE>
Save, save, save. That's what most of us had to do. Honestly, if you're wanting speed. It's going to be hard to find with the b16a2. Trust me, I wanted a b16a for the longest time. Than I raced my buddy with my EJ1 coupe (d16z6) and we were even the whole time. He BARELY pulled me. From that day forward, I've had my mind set on a b18c.
Save, save, save. That's what most of us had to do. Honestly, if you're wanting speed. It's going to be hard to find with the b16a2. Trust me, I wanted a b16a for the longest time. Than I raced my buddy with my EJ1 coupe (d16z6) and we were even the whole time. He BARELY pulled me. From that day forward, I've had my mind set on a b18c.</TD></TR></TABLE>
Unless your car was lighter and modded, your friend must be a pretty rotten driver. It won't be like he would smash you to pieces with his a2, but you should not be able to hang with him like you describe. Anyway, just MHO.
Re: lsd for $300 (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">Unless your car was lighter and modded, your friend must be a pretty rotten driver. It won't be like he would smash you to pieces with his a2, but you should not be able to hang with him like you describe. Anyway, just MHO.</TD></TR></TABLE>
We both had the common I/H/E. He was in an EM1 and I was in my EJ1, and neither of us are 'rotten' drivers. The b16a is more or the less the z6 with an extra camshaft. Get the b18c, you'll be happier.
